Jio fiber connection speeds lower than promised in plan
sanjayandheri
MTNL
Have Jio Fiber 150 mbps plan, but yet to get speeds> 90mbps on a laptop connected directly to LAN port of Jio Router !! Jio Call centre proved to be useless in resolving the issue. Not sure if there is issue with router or back end server which throttles the speed.
what is your laptop model?
Your laptop LAN port is 100mbps max.
Laptop has lan connection port , which has been tested at other places. LAN ports of Jio Router has speed limitation to 100 mbps, either by design or fault, not sure.
Any one having Jio Router which gives speed more than 100 mbps on LAN ports ?
Speed tests on 5ghz shows 150 mbps as per the Plan. The issue is not about Wifi Speed on router but Lan ports having a speed limitation of 100 Mbps .
