i installed custom rom on the jio set top box by following:
Download Link for C200:
Download Link for D200
Password: mishraaajeee )
Amlogic tools All version:
How to Install
Flashing Instructions:
Step1 : Copy all the files from downloaded zip file to amlogic bin folder.
Step2 : Connect the box in Worldcup mode and execute flash_atv.bat from amlogic bin folder. (please dont ask me how to install amlogic tools and bring it to worldcup mode . Simple google search will do)
It will take 5 minutes to flash both system and vendor images. It wil Restart automatically and first boot takes some time so be patient.
Connect usb keyboard or Android Tv Remote in mobile to skip the initial setup screen and pair the jio remote from Remotes & Accessories tab in settings.
New Android Ui will come only after you update the google apps in playstore
Update All apps from google store on first boot (must before trying anything) and enjoy the ATV experience..
Now i want to revert to stock firmware... can anyone help me do that; i found stock firmware on the site under the post:
broadband.forum
but it did not mention how i can install the firmware; should it done via ADB?
Also my understanding is that it the D200 modem goes into recovery when the reset button is held and device is powered on..
How to Install
Jio STB JHSD200 OTA Link | Reliance JioFiber
Hi everyone, I was able to capture latest OTA url for Jio STB. Mirror: STB-JHSD200-5.7.1.zip | by YashRastogi for Generic Device/Other URL: http://fota.slv.fxd.jiophone.net/STB/Droidlogic/JHSD200/STB-JHSD200-5.7.1.zip Hope it is helpful for various purposes.
