Jiofiber randomly stops working on devices
  • Thread starter Thread starter FuckISPs
  • Replies Replies 5
  • Views Views 1,090
India
Reliance JIO
Router model: JCO4032
Firmware Version: SRCMTF1_JCO4032_R2.41
A device will work one day, and then the next day it stops working. Happened with my VMs, my TV and my PC. TV was connected by wifi and PC and VM were connected via Ethernet. Resetting the client device wouldn't work, you have to reset the router and lose all your settings. After resetting, if you import your exported settings it stops working again. From another thread, someone asked to try turning off "Security > Firewall > Client Access Control". I've done that and will keep you guys updated. Also, does anyone know how to remove the time-limit on the router configuration page? It turns off after 3 minutes.
Also, I don't know why, but unless I ping reliance.reliance (resolves to IPV6 address of router), the IPV6 IP of my VM won't show up on the Lan Clients list.
Is Airtel any better or do they have the same shady practices as Jio? Does Airtel allow you to have a custom ONT other than OEM?
