LED TV from Malaysia or Singapore
  • Thread starter Thread starter Deleted member 7160
  • Replies Replies 73
  • Views Views 36,562
D
Deleted member 7160
Would be travelling to Malaysia and Singapore in March & would like to buy an LED TV. I have zeroed in on https://www.samsungindiaestore.com/Products/Television/40ES5600_40ES5600 The cost on online Samsung store is 62K, But the prices in retail is almost 52K.
Am basically looking for 40" LED full HD. In case there are any other models which are similar specs (Sony/LG), Please recommend me.
Also, If anyone has bought TV from the above countries let me know the shops and the procedure from customs.
Thanks!
ok my friend is going to bankok on 29th............i am willing to get [color=rgb(40,40,40);font-family:'Droid Sans', helvetica, arial, sans-serif;]ES5600[/color]
is it available in india ?? so it will be repaired easily ?
will i get it cheap in bankok??
Incase of unavailability of ES5600, please suggest similar or tad bit better models please, I really want to use this opportunity to get cheap led tv :D
Sony 40EX650.
I have a document that I had compiled (and given a printout of) which contains the names and addresses of the shops where to buy from, models and the procedure of getting it. If you want I can send it to you.
@ manu bhai , i ilke the model , but its 100hz only , can u please advise any model of 400hz for even 5000-6000 extra rupees?
thanks a lot bhai
Don't know.But I think you'll have to get the 7 series for a better refresh rate which will be at least 15000 Rs. extra
