So why not you try urself,install the VPN disconnect and reconnect your internet,check the usage and than start vpn and download 200/300 mb file and disconnect and reconnect and check your usage again and see if its added to ur usage
PS: I'm sharing this now as it seems that the BSNL plans, and also other ISP plans have gone very cheap. This is not hacking, BSNL is already aware of this and there's nothing they can do for ADSL connections, maybe.
I have been using BSNL BB for about 6 years. Surrendered and got it reconnected as I was away for college.
Earlier I was on 1745 ULD plan. 8Mbps up to 30GB. So, what I did:
I kept track of the data usage using a python script
as the FUP was about to expire(nearing 30GB), I switched the ADSL power to a 12V battery with 9V step-down, so as to avoid any power interruption.
power cycled the modem, also installed a fan for active cooling
and started my scheduled download.
As the modem was constantly on, the data rate wasn't reduced even after it crossed 30GB FUP.
BSNL disconnects every user after 24Hours of continuous usage.
After which the speed gets reduced and the FUP notices pop up.
So, 24hours of continuous download at 1MBps back then at 2015 was a pretty great deal.
