Low speed with MTNL
  • Thread starter Thread starter Gladson
  • Replies Replies 35
  • Views Views 6,155
The main trick is to get them to somehow sync you to 4096 kbps. This way you will always get 2 mbps exact download speed. Any sync rate above 2048 will do.
Back in the day when I'd got Mtnl, I'd pester them with slow speed complaints and eventually they got tired and synced me at 2550 :PI'd been getting 1.8 Mbps, jumped up to 2 since that day. Maybe you'll could try that.
Yes I found out that 2 days ago when I found one of friends is synced to 4096. But how do I get them to do that. Any ideas? :D
I tried that low speed trick even went upto the server room but they told me that its ok from their side. DGM's tell me the speed I get is more than 80% of 2Mbps which is technically true. :) Data rate Downstream = 2013 & Upstream = 1021 :( Incidentally I use a D-Link DSL 502T ADSL modem.
I'm on DSL 1333 and over the 2 weeks I do not get more than 1.5-1.6 Mbps at night & on Sunday i wrote to my area DGM but got no response and i see my downstream earlier was 2148 but now its 2012 also the downstream stays 2012 for entire day but speed changes after night hours also previously the connection was interleaved but now its changed to Fast how can i get them to fix my problem ?
Have emailed them since 2 days they say its ok how can it be ok that the downstream is 2048 for entire day and i get 1mbps on day and 1.6Mbps at night
ADSL_2plus
ATM
Up
L0
OnOn
427288
215147
167124
192761229
[TD="class: hd, bgcolor: #E0E0E0, colspan: 2"]Mode:[/TD]
[TD="class: hd, bgcolor: #E0E0E0, colspan: 2"]Traffic Type:[/TD]
[TD="class: hd, bgcolor: #E0E0E0, colspan: 2"]Status:[/TD]
[TD="class: hd, bgcolor: #E0E0E0, colspan: 2"]Link Power State:[/TD]
[TD="colspan: 3"] [/TD]
[TD="class: hd, bgcolor: #E0E0E0"] [/TD]
[TD="class: hd, bgcolor: #E0E0E0"]Downstream[/TD]
[TD="class: hd, bgcolor: #E0E0E0"]Upstream[/TD]
[TD="class: hd, bgcolor: #E0E0E0"]Line Coding(Trellis):[/TD]
[TD="class: hd, bgcolor: #E0E0E0"]SNR Margin (0.1 dB):[/TD]
[TD="class: hd, bgcolor: #E0E0E0"]Attenuation (0.1 dB):[/TD]
[TD="class: hd, bgcolor: #E0E0E0"]Output Power (0.1 dBm):[/TD]
[TD="class: hd, bgcolor: #E0E0E0"]Attainable Rate (Kbps):[/TD]
204850900
591600
641500
1100
1300
0000
1.00.98460.00.0
52013000
1100
0.250.240.00.0
0.00.00.00.0
0000
3000
0204592800
0000
0000
2000
0000
0000
7547998187269200
50256813055700
0000
[TD="class: hd, bgcolor: #E0E0E0"]Path 0[/TD]
[TD="class: hd, bgcolor: #E0E0E0"]Path 1[/TD]
[TD="class: hd, bgcolor: #E0E0E0"]Rate (Kbps):[/TD]
[TD="colspan: 5"] [/TD]
[TD="class: hd, bgcolor: #E0E0E0"]MSGc (# of bytes in overhead channel message):[/TD]
[TD="class: hd, bgcolor: #E0E0E0"]B (# of bytes in Mux Data Frame):[/TD]
[TD="class: hd, bgcolor: #E0E0E0"]M (# of Mux Data Frames in FEC Data Frame):[/TD]
[TD="class: hd, bgcolor: #E0E0E0"]T (Mux Data Frames over sync bytes):[/TD]
[TD="class: hd, bgcolor: #E0E0E0"]R (# of check bytes in FEC Data Frame):[/TD]
[TD="class: hd, bgcolor: #E0E0E0"]S (ratio of FEC over PMD Data Frame length):[/TD]
[TD="class: hd, bgcolor: #E0E0E0"]L (# of bits in PMD Data Frame):[/TD]
[TD="class: hd, bgcolor: #E0E0E0"]D (interleaver depth):[/TD]
[TD="class: hd, bgcolor: #E0E0E0"]Delay (msec):[/TD]
[TD="class: hd, bgcolor: #E0E0E0"]INP (DMT symbol):[/TD]
[TD="class: hd, bgcolor: #E0E0E0"]Super Frames:[/TD]
[TD="class: hd, bgcolor: #E0E0E0"]Super Frame Errors:[/TD]
[TD="class: hd, bgcolor: #E0E0E0"]RS Words:[/TD]
[TD="class: hd, bgcolor: #E0E0E0"]RS Correctable Errors:[/TD]
[TD="class: hd, bgcolor: #E0E0E0"]RS Uncorrectable Errors:[/TD]
[TD="class: hd, bgcolor: #E0E0E0"]HEC Errors:[/TD]
[TD="class: hd, bgcolor: #E0E0E0"]OCD Errors:[/TD]
[TD="class: hd, bgcolor: #E0E0E0"]LCD Errors:[/TD]
[TD="class: hd, bgcolor: #E0E0E0"]Total Cells:[/TD]
[TD="class: hd, bgcolor: #E0E0E0"]Data Cells:[/TD]
[TD="class: hd, bgcolor: #E0E0E0"]Bit Errors:[/TD]
No, speed profile is your actual connection speed as set by the exchange. Downstream rate is your sync rate.
