Low Voltage Suggest PC + Crt 21 TV Stabilizer.
  • Thread starter Thread starter anilsethi04
  • Replies Replies 12
  • Views Views 4,136
If you can invest and have contact(or ask local shops), go for custom made stabilizer, it cost me around 18k but can take load of my entire house in village having all the item like tv, fridge etc... It works even when power can only heat the bulbs filament(ie below than 90 volts), though you may not like the look and size, its bigger than a crt tv set and uses oil as coolant.
Thats interesting. How is this connected to whole house load? Is it connected to the main DB?
You would need something like this
Stabilizer - Volt Stabilizer | Voltage Stabilizers :: V-Guard or A Multikonect double booster stablizer. It would handle A TV, DVD player, Home theatre + DTH. Double booster stabilizers boosts the low voltage to the minimum required. I have it for my Airconditioner, very useful for summer nights when everybody use AC ...
Buy 2 multiconnect double booster stablizers one for TV n other devices connected to it. One for PC ... It normally tailor made. You just need to order to make one for your requirement directly to the CO or distributers. Retailers normally don't stock it.
I have premier brand. It manufacturing unit is in TN. So it was easy for me to order n make one for my requirement.
Yep!
