guys do u find low volume as compared to other channels on TIMES NOW and ANIMAL PLANET? do u also face the same problem.
There is no problem in my set Volume is ok.
Volume level is not uniform in some channels. Normally I lst the vol level to 60% in the TV and adjust STB volume control for normal viewing. In some channels, the tv vol has to be increased for acceptable sound.
Earlier I was facing same problem with NDTV India, Audio was so low, that I had to raise TV volume to hear, and later if I changed channel, suddenly there was loud sound for changed channel. But after 2-3 days problem was solved
