vishalrao
The Global Village Idiot
- Messages
- 6,448
- Location
- Pune
- ISP
- Tata Play 1 gbps, Jio AirFiber 100 mbps. Prior Microscan 500 mbps, PDPL 300 mbps and BSNL 300 mbps.
Lets say there are two mesh wifi systems, one with dedicated wifi 5 ac 5ghz 1700 mbps rated backhaul and another also with dedicated backhaul of same rated link speed but using wifi 6 ax 5ghz.
The first one's real world backhaul link speed maxes out at 400 mbps with certain placement of distance and walls in between the main router and satellite.
Will the second one backhaul link speed also max out at around 400 mbps with the same layout or will there be any significant difference thanks to it being wifi 6 even though both are using 5ghz?
