Check Mi Power Bank Pro Deals on: Flipkart | Amazon | Paytm
USB-C port is there. USB-PD does not seem to be there.
10000mAh Mi Power Bank Pro - Mi India
Type-C charging | High density batteries | Two-way fast charging | 12.58mm thin
USB Type-C charging
The micro USB cable comes with a Type-C adapter for a wide range of charging options that support phones,
tablets, notebooks, and more. Simply pair with your own cable to charge iOS devices.
18W fast charging both ways
Whether it's charging others or getting charged,
10000mAh Mi Power Bank Pro moves fast.
With up to 18W fast charging, it intelligently adjusts power
output to safely charge each connected device.
Double press for low power charging
Safely charge low power devices such as bluetooth headsets or fitness bands.
Simply double press the power button to enter 2-hour low power charging.
Incredibly dense, 10000mAh batteries supplied by ATL/Lishen are used to satisfy the portable power needs for your phone, tablet, camera, and more.
