Mornings V/S Other times ping and jitter problem in Cloud Gaming
@luffysingh it doesn't matter if they got RTX on there servers or whatever. You'll never experience the same experience of a local PC
I've just tested it myself and found very poor graphic quality as well as poor gaming experience on OnePlay Cloud Gaming.
I've myself RTX 3090 with G-Sync Monitor. I Can totally see lot of difference in the gaming. It's better if you play on 720p monitor but not worth for 1080p or 1440p monitor. I've tested Tekken 8 and it's just a Sh-- from my opinion.
@luffysingh if you are getting poor response by BSNL Fiber team?
Put complaint on this website : BSNL|PGRMS
Your complaint will be directly handle by some higher officers and you'll surely get your connection resolved within 1 - 2 weeks. I've done it myself few months ago and got my connection problems resolved in 1-go
@Protector I just want to ask did you face any ping or lag issue during trying oneplay I’m not talking about game graphics but during game streaming and what bitrate did you played on?
@luffysingh Let's talk about my experience in a few more details as per your questioning.
1. Ping : Tekken 8 require Open NAT Type to play it at smooth pace. Thankfully, My NAT Type is convertible and i've set it to Open NAT before playing the game. Regarding Ping issue, There is 10ms higher Ping than it used to be on my PC or Console, So you can expect that OnePlay servers aren't upto mark in case of Ping structure. although 10ms doesn't vary that much but it does give some boost too if you got less 10ms ping.
2. Lag : Tekken 8 require Mid-High End PC to play at 2k - 4k Graphics, Luckily my PC can handle it easily, as I've been trying to play it on OnePlay platform, I can see that there is Shuttering & 60FPS Lock on Tekken 8. So, I can't play that much smoothly but there is no Lag issue i faced while using OnePlay. (although i think there Servers are not that stable and still required some more major fundings).
3. Bitrate : I've adjusted the bitrate to 45,000 - 50,000 (~50mbps) (that's the bitrate i've setup). So, You can say I'm play on 1440p 120FPS resolutions bitrate (as per recommendation). But, It was not worth the quality as 45k - 50k bitrate just looks like 720p 60fps which makes me close the launcher and uninstall it immediately as i've been doing gaming since a long time but this OnePlay application isn't what i've expected it to be. Although if you are at 720p Monitors, You are better to play on it if you want but anything above 1080p will be curse.
If you want to ask any further questions, just @Protector me & i'll try to give proper reply for it
Nice but did you tried any other games because I’m seeing a lot of guys playing it very smoothly here are some gameplay videos @Protector
1st one he is playing from USA(connected to Mumbai server):
2nd One a guy From India played AC Mirage(currently Ubisoft games aren’t available) :
I've viewed your source provided videos and can confirm that my above message is appropriate with your recommended stream.
2nd guy playing Assassin's Creed game shows too much Shuttering and Blurry while moving his moments and mouse. I can also see too much pixels on it resulting bad experience in 1080p.
Checkout 480p - 720p and 1080p. You'll find no difference in 720p - 1080p sadly due to poor encoding on OnePlay and FPS Limit. (although at server it is above 200FPS but encode is 120FPS - 90FPS)
Above videos which are comparison, I can see that Boosteroid got much more shuttering and pixels than OnePlay.
Well, I'm just putting up my opinion. But from above 2 clients, It's better to use OnePlay in place of Boosteroid.
Also, I don't see any Smooth gameplay in these videos as i can see 1 - 2 seconds random pauses in-between the video (if you watch it carefully during missions or story start-mid-end at that points).
Anyways, I'm saying that Cloud Gaming is still not best solution for it as These cloud gamings aren't even providing 70 - 80% experience properly.
So, Other people which are playing games smoothly probably doesn't care about bit of shutters and other things that's why they are enjoying it.
Also, I don't test other games because i don't trust 3rd-party platforms personally + Rs. 50 trial is over too 😜 . I got a good PC for myself and i'm happy with it.
P.S. : Compare your game with this one and you'll 100% see a large difference in it
Maybe it’s good for me cuz I got 1080p display only and I don’t have a gaming pc. So cloud gaming is my only way to play high end games if the ping and jitter is good.
@luffysingh
Tracert 13.126.169.8
C:\Users\user>tracert 13.126.169.8
Tracing route to ec2-13-126-169-8.ap-south-1.compute.amazonaws.com [13.126.169.8]
over a maximum of 30 hops:
1 1 ms <1 ms <1 ms 192.168.1.1
2 2 ms 2 ms 2 ms 61.0.xx.x
3 4 ms 3 ms 3 ms 10.219.xx.xx
4 * * * Request timed out.
5 * * * Request timed out.
6 * * * Request timed out.
7 * * * Request timed out.
8 * * * Request timed out.
9 17 ms 18 ms 17 ms 99.83.66.228
10 20 ms 17 ms 19 ms 52.93.98.142
11 18 ms 19 ms 19 ms 52.93.116.141
12 * * * Request timed out.
13 15 ms 16 ms 17 ms 52.95.66.54
14 28 ms 29 ms 25 ms 52.95.64.160
15 22 ms 20 ms 25 ms 52.95.64.173
16 30 ms 29 ms 27 ms 99.83.76.37
17 27 ms 28 ms 26 ms 99.83.76.46
18 * * * Request timed out.
19 * * * Request timed out.
20 * * * Request timed out.
21 * * * Request timed out.
22 * * * Request timed out.
23 * * * Request timed out.
24 * * * Request timed out.
25 * * * Request timed out.
26 * * * Request timed out.
27 * * * Request timed out.
28 * * * Request timed out.
29 * * * Request timed out.
30 * * * Request timed out.
Trace complete.
Tracert google.com
PS C:\Users\user> tracert google.com
Tracing route to google.com [2404:6800:4009:823::200e]
1 1 ms <1 ms <1 ms 2001:4490:4828:xxxxxxx:48ff:fe04:fb08
3 3 ms 3 ms 3 ms 2001:4490:3bfc::108
7 18 ms 18 ms 18 ms 2001:4490:effc:1::4:2
10 14 ms * 17 ms 2404:6800:812e::1
11 20 ms 20 ms 18 ms 2001:4860:0:1::5392
12 4 ms 4 ms 4 ms 2001:4860:0:1::78bc
13 15 ms 14 ms 64 ms 2001:4860::9:4001:ddce
14 17 ms 18 ms 20 ms 2001:4860::9:4001:d9e7
15 13 ms 12 ms 15 ms 2001:4860::9:4001:7733
16 14 ms 15 ms 19 ms bom12s13-in-x0e.1e100.net [2404:6800:4009:823::200e]
Trace complete.
