Moto E3 Power not detected on PC
  • Thread starter Thread starter Deleted member 10390
  • Replies Replies 8
  • Views Views 6,477
D
When I plugin the USB cable connecting Phone and PC, there is no indication of mounted storage on PC. Is there anything in settings I should be checking ?
Last time I did something about USB debugging. Where can I find it in settings ? I have Andriod 6.0
try a different usb cable. that's all i can think of. usb-c requires you to change a setting from notification to switch from charging to data transfer. microusb should not require anything.
It's normal USB to USB mini cable that comes as a part of the charger. Not USB Type C.
I enabled " Developer Options " and used USB debugging. No luck :(
try with another cable. cables can and do go bad. and of course, if your sole need is data transfer, you can do it using any third party app. even file managers allow you to do file transfers between phone storage and network storage.
by default it will connect in charging mode. you need to change it to file transfer mode in the notification on the phone
Where can I find that option ? I recently Factory Reset this phone. It is happening ever since. There is no notification on " Charging " as well.
If you are on wifi use wifi transfer apps like airdriod, sharelink etc.
I did try Xender. I tried to upload an apk as file by choosing " All files " option in file type. I am able to initiate upload. But no further action is taken on it. There is no corresponding apk on the phone. That's why I tried USB cable.
