MTNL Broadband: Help for Port Forwarding on DLink 502T
  • Thread starter Thread starter rohaan
  • Replies Replies 3
  • Views Views 2,033
rohaan
Regular
Navi Mumbai
MTNL 999 UL
Hi There all,I have MTNL 849NU plan and I was getting very low speeds around 25 KBps which I think is very slow considering a 2Mbps plan. So I wanted port forward. My main doubt is that when u add a Rule in Virtual Server, what should be the protocol. Port Forward says it should be TCP for uTorrent. So should I go ahead with setting the protocol as TCP.My Torrent client is uTorrent.Thanks in advance.:D
Guys I have Port Forwarded and I get a green check in uTorrent but the speeds r still very slow as they were with Dynamic IP. No difference after port forwarding. I have set my upload speed at 22 KBps. The port no. which I have forwarded is 52064. Pls help me out.:huh:
the speed may also be dependent on what you're downloading and how many sources you have for itCheck that and get back cause everything else sounds okYou might also want to try posting your stats from your modem's page
