MTNL Broadband: Need Help , on T-KD 318 Router ! | Wifi
  • Thread starter Thread starter Ninja
  • Replies Replies 4
  • Views Views 5,868
Ninja
MTNL
Well
I have two scenario one
http://img524.imageshack.us/my.php?image=snapshotlb8.jpghttp://g.imageshack.us/thpix.php
I got MTNL T-KD 318 EUI Model Router
now i am a heavy torrent downloader so i
am using Bridge mode , dialling to
Connect ( it giving me a good speed ) ,
Now the problem is that i got a desktop
and a laptop and i am using usb
Connection for desktop and for laptop i
am using a standard RJ45 line which u
get a standard option in MTNL router in
which u can use both USB / LAN option ,
now both the connection working well i
able to dial but one at a time i cant
use both if i dialled in Desktop (using
USB port ) then i open my laptop and try
dialling ( LAN ) dialler says " connecting
to pppoe through WAN " something this
sort ..so i cant use internet
simultaneously in both the system visa
versa,
Question 1)- is it possible to make a
bridge connection which can be used in
both the sys together or i have to use
one at a time .
Question 2 ) now other thing i also want
to interact with my pc and laptop for
sharing files and updating can i ? with
above router ? if yes then how ?
Scenario 2
Now i am also planning to use a Wifi
ADSL router and planning to buy a
Linksys router which i suppose
recommended highly here ..
i know Linksys has standard 4 RJ45 port
and RJ11 ( for adsl / adsl2+ )
connections , is it possible to use
bridge mode together in both Desktop and
Laptop ? i am planning to connect
Desktop through the standard RJ45 and
Laptop through Wifi G/n i know i have
other threads to look for config how to
secure or configure my connection so i
will do that but my ..
Questions 1 will i able to link Laptop
and my Desktop ( which connected through
RJ45 port to my Linksys router ) able to share
my files frm desktop to laptop visa
versa? vlan ? if yes how ?
Question 2 will i able to use my Pc using
wired RJ45 and Wifi G to laptop using bridge
mode able to usee internet both at same time
New Page 1
only for reference with screen shots. for Modem T_KD 318.
Menu pages similar to one model UT300R2U and Beetel 220BX series.
For sharing files across 2 machines using a Linksys WiFi router check out
Socrates?s experience: Sharing files/folders across machines thru Linksys WRT54G
& for setting up of Linksys WRT54G check out
Socrates?s experience: How to configure Linksys WRT54G wireless router
Thanks ! For Wifi solution ! it is very helpful ! i wish i could get the first things sorted using bridge mode ! problem ! but thats ok thanks !
New Page 1
Thanks Essbebe ! nice nic lol but what i has to show not the model of my router but the bridge mode settings of my router , but thanks for the information ! i keep that in mind thanks for the help ! :thumb:
@ninja 1.In the screen shots see the "connection" page . select "bridged" now PPP/PPPoEin your modem Save reboot. 2.Use Dialer(Wanminiport) to connect.3.You should confirm, that you are connecting to Internet in any mode. "always on" or in " bridged"Mode.4.Then try wireless settings.5Then try for any change for connecting to Internet.6. then ask for Port forwARDING.7. then ask about torrents download problems.8.then ask about automatic settings for NU. 9. then ask about sharing files/folders between two computers.10. then complain about speed etc !!!!
