parthapain
Hi, Recently i got my mtnl adsl connection setup. I have a laptop and a pc at my premises. The laptop is wireless compatible. However i am having trouble setting in up.The wireless network is up, as the laptop can detect it. I can also connect to it.But after connecting, no data is getting exchanged. My settings are as follows :Ip -192.168.1.7Subnet mask -255.255.255.0Default gateway - 192.168.1.1 Preferred DNS server- 203.94.227.70Alternate DNS server- 203.94.243.70 On my router the following setup is enabled. Wireless SSID - DLINK_WIRELESSVLAN_ID - 0Priority - 0Channel - 6Security - None DHCP - It is selected Starting Ip address -192.168.1.2Ending Ip address -192.168.1.254DNS mode - AutoLease time -3600 LAN I.P address -192.168.1.1Subnet Mask -255.255.255.0 WAN Pvc0VPI -0VCI -32Virtual Cicuit - EnabledWAN setting -PPOE/PPoA Authentication Type - Auto Connection Type - PPPoE Default Route - Enabled PPPoE Pass Through - Disabled NAT - Enabled Firewall - Enabled IP Control - Dynamic IP Could someone help me on this please? P.s - i am unable to ping 192.168.1.1 when i am connected through wireless. When connected through LAN wire everything works fine. Thanks Partha
