Mtnl speed suddenly Reduced
unlimited, as I said, a couple of my friends are still gettin it
As i said in my above post, Your "Golden Hour" now ends and you will have a fixed bandwidth where in you will get a fixed transfer rate. Your friends might enjoy it for some time, but once its noticed by the Mtnl officials, they will sync it as per their plan
Well, going by the subject of this discussion alone, I can confirm that my speed has decreased from 0.63 Mbps to 0.49 Mbps for about 2-3 days now. Upload speed has also proportionally decreased. This, when I'm paying for 0.752 Mbps plan. Looks like they're going green.
I have been facing slow download speed problems in the last 2 weeks. I am using the 590 Night unlimited download since 2006 which should be giving me download speed of 256kbps ( 2 Mbps bandwidth). However since the last two weeks i'm getting download speeds of just 20-30 kbps. Sometimes after an hour of connection the ADSL light on my D-Link 502-T goes off. MTNL guys have called saying they will look into it. I'm aware of their pathetic service since i am using MTNL since 2006 so not keeping any hopes on them.. have any other Night unlimited users been facing such problems??? looking for some help!!
^ facing the same problem. except that am on UT Star modem from MTNL(shuldnt matter). have complained to MTNL but no fix yet.
@deskjet86 and @powerontop - I had issues of erratic speed and frequent disconnection for several months. The first significant improvement came when they replaced a cable in the last mile. But the problem was still not completely solved. Then I managed to persuade them that maybe my modem had gone bad. They replaced my modem and since then I have had no problem at all.
