MTNL Triband Broadband: Downloading problems with 749NU plan
  • Thread starter Thread starter abtom
  • Replies Replies 39
  • Views Views 7,103
guys, i upgraded to the 749NU plan this month. after a lot of fretting, my speeds got upgraded. now, when i download from limewire and http servers, i get speeds aroun 150kBps, but in torrents it hovers around 50-80kBps :( why is this so?? port is forwarded. any particular setting i should change in my torrent client or router page?? i've tried multiple torrent clients but get the same prob
but scorpio is able to DL 6-7 GB and m just 3.5GB.help guyz.mm using utorrent.i have these setting on my BT clientDL speed-250kBpsUL speed-20kBps.DLing torrents from link-removed,torrentbytes.@scorpio ,but lol,even with constant 230kBps,u cant go over 6.7 GB in exact 8 hours.u can DL for only 7hrs and 30 mins.Speed is also not constant on torrents.and then ,7GB in 8 hrs or so...............:confused::confused::confused:
be happy with those speeds man...i suffer through 40-50kBps on 3 simultaneous torrents, cuz theyre old with few s/p . Only with new well seeded torrents can I hope of 100+btw how much wastage do u guys see on ur torrents, for me its upto 200-300MB on a single 4GB torrent ....lool
arre bhailog,meri problem to solve karo.3 GB in a nite,hhhhmmmm.....not done.
upto 7 GB/night on Torrents :)
@abtom
17 or more Torrents lined up so I'm sure to get the max 1.8mbps all night long
Trackers going offline.....Superseeders going off line,and various other issues cause indivdual torrent speeds to vary.:(
So since I have so many torrents in the pipeline if one has slow speeds someone other torrent DL's when it gets the chance:thumbsup:
I use uTorrent,UL is limited to 6kbps(google about why 6 and no less) and I have other software to ensure my ratio on trackers stays at 1:whistle:
Trackers:link-removed,bwtorrents,exdesi.com,etc
:O:O:Odoes this lining up of 18 torrents really work?if so i am going 4 it.BTW DLed abt 4GB yesterday nite.
6 kBps ul-too low.deos it work?what DL speed u set?Update-not 4GB but 4.7GB i was able to DL last night.session history shows 1500 MB whreas my BT client shows 4.7GB.and my BT client is right as i have Dled 4.7GB.got 200+kBps speeds on 3 torrents.i think i will get more i f i DL more torrents simultaneously as skorpio [email protected] said u get 1.8mbps speeds but u r getting 202kBps which is arnd 1.7mbps.BTW i also get 1.7 mbps speeds.what is the max no. of active torrents u set and max DL torrents?does it affect speeds in any kind(increase or decrease)?hope it does not decrease the speed.which software u have whick keeps ur ratio to 1.i also want that as my ratio on torrentbytes is .020.please help.
