Friends,
I need to get a second connection (multi TV, pls see below link) for my existing Airtel Digital TV connection.
http://www.airtel.in/wps/wcm/connect/DTH/bharti+dth/packages+for+you/multiple+tvs/
Now I am worried about how the cabling will be done for these two connections as second room where I propose to install my new second connection is on the other side of the house. Does the cabling will be done from the first set box or directly from dish antenna? If they are doing it from dish then well and good and I can go ahead but in case splitter is installed at first set top box and cabling is done from room to room I am afraid that I have to give up my idea as I don’t want ugly wiring in my house.
Can any one having multi tv connection please help me. Thanks in anticipation.
