Multiroom charges for Airtel DTH?
  • Thread starter Thread starter nikeel
  • Replies Replies 7
  • Views Views 3,964
nikeel
Techans
MTNL Triband 384kbps UL
What are the charges for Multiroom subscription (more than 1 TV in the house) for Airtel DTH?Couldn't find it anywhere on the website.
:wall:Hi... u would be surprised to know that there is no such option available with Airtel as of now...u need to buy the STB which will cost you 2500 that's 500 rs less and u'll get 1 month free subscription on the second television ...after that .. just GUESS..u need to pay the full amount for the second television also.. for example..if you go for RS 424 PM plan then you will have to pay Rs 848 from second month for 2 television's...AIRETL is CRAP
i can't believe that :confused:
such idiots
well big tv on the other hand gives 50%off on the subscription but that applies only if u complete a 1year period in ur secong connection only there after does the 50% off applies.
but beware of their service,which is very slow to respond if they say its 48hrs its more like 480hrs to respond.:@
Well, I spoke to Airtel they said, STB is 2500 rs and then additional would be 99rs / month. So if u have 424 PM package then additional rooms u will pay only 99rs.
strange, does not say so on their webiste though:huh:
Just spoke to Airtel CC and they say that there is no such option of Rs.99 for the second TV. You have to pay the full amount !!!!:wall:
The only discount that u get is Rs.500 on your installation :wall:
