as told earlier, everything about charging, can only be confirm by airtel itself.
contact them and get all your query will be answered there only in best way.
Maybe just check if your IP stays same after 5-10 reboots xD. If you are using bridge mode you will have to manually set the static IP provided by airtel in your other router.
I don't care about these sites results.
I am using static IP, using Airtel's ONT, no bridge mode.
I have setup port forwarding in ONT as well for specific ports I need to forward.
When i start those applications for which I enabled the port, they work pretty well.
That's being said, my needs are fulfilled by the Airtel, Using the static IP.
