Need 1 ton ac for 100 sqft room on top floor
minuteman
I Eat Internet
Antarctica
Airtel Xstream Fiber
BSNL FTTH
Airtel 4g
Jio 4g
Suggest me a best split AC with wifi for top floor since it is only 100 sqft 1 ton is enough right sunlight hitting only on the roof rest of the walls are inside no direct sunlight. Thinking of buying LG ai+ 1 ton ac is it a good brand with after sales service will it last for 20 years?
He was basically referring to my post that LG 1.5T split is very good. The room on roof of my place gets pretty horribly hot during summers. If you think 1T would be enough, get that I suppose. AC guy might be able to confirm though.
The additional .5 to is to compensate the additional heat coming from the top floor. For the given area under normal situation a 1 ton would suffice but because of additional heating from the roof, your AC would be working more to remove that heat. .
If you can get 1.25 Tom like those from the Hitachi you are good to go.
Else 1.5 Inverter from LG, Panasonic are my recommendations.
and you can run todays inverter ac in 40-80% mode too and it get quite efficient in lower mode. So run your 1.5 ton in 60-80% to save more.
I would recommend 3star ac for just 2 hrs usage not worth to spend more on 5 star.
So better spend on 1.5ton 3star ac rather than 1ton 5star ac.
That way you would get enough cooling for any 50deg future summer seasons.
Rubbish!!! Try calling LG CC and fix an appointment for AC installation. Remember to get it vacuumed during installation.
but reliance already took the ac installation cost of ₹1415 from me if I contact LG cc do I need to pay the same amount again?
@minuteman Reliance team is LG authorised installer too like jeeves is auth for lg ac sold via flipkart. But what is ac worth if u don't use for 1 month. Your warranty starts from day 1.
You should have argued before buying. Go to store and make some noise to get installation date changed or installation refund and get it from lg directly.
I concur with what igloo has mentioned. Waiting for a month is just ridiculous.
Yes, when LG guys came to setup my AC, they did take the installation amount. Don't recall how much.
