Is airtel hotspot supports ca ?
If supports upto which level?
Is platinum postpaid plans has better qos than others?
Is there any hotspot available in india which supports ca?
1. No
2. Network speeds? At the moment, no. But you get sort of better customer support.
3. Don’t think so. Even if one had to import, it’d be very expensive and may not support all bands or CA in a particular combo.
