@Lolita_Magnum
Issue with DPI is slow loading web pages despite a good ping, making the experience pathetic.
I understand what DPI is and that it is set up on the ISP servers, not on my
ONT. However, DPI is causing issues where certain apps, like
Flipkart, stop showing pages like "My Cart" or "Account." Using winws to bypass DPI unfortunately breaks these services entirely.
Regarding Jio throttling
WARP: they are limiting speeds from their end. I've noted that Jio now caps speeds at approximately 150Mbps when using Cloudflare WARP, whereas previously, using WARP provided a more stable connection and better speeds.
I mentioned having a rooted ONT to clarify that I can set up any program you suggest directly on the device without needing an additional
router in bridge mode. The primary issue remains the DPI-induced slow loading of webpages and video buffering on apps like
Hotstar (despite having a plan capable of 4K streaming). Additionally, services like Imgur, Reddit, and X.com often fail to load as if they are being blocked.
If there is a solution to fix this speed throttling on Cloudflare WARP by Jio, it would be extremely helpful, as Cloudflare’s routing is generally excellent.
(I dont think there is any problem that i corrected my grammar using gemini)
