Need help for bridge sharpvision as341 wt(ont) with nokia g-140w f as my router(extender)
  • Thread starter Thread starter jothis
  • Replies Replies 2
  • Views Views 973
tamil nadu
bsnl
Hey guys i have sharpvision as341 wt as my ont and i have Nokia g-140w f as my router(extender) provided both of the routers login page can someone help me with bridging it? first img: my ont sec img: nokia router
fi
Both are ONTs and they both take Optical input. Bridge mode won't work.
To use bridge mode you need:
1) ONT with bridge mode enabled
2) Router with WAN input and PPPOE support.
You can still use Nokia as an Extender with Sharpvision ONT in route mode. I think you will need to connect ont with Nokia via lan and disable dhcp mode on Nokia to make it work but the LOS light on Nokia will keep blinking.
yeah for alternative i changed my Nokia into a access point bcoz of lacking of wan port
step 1.changed my router ip to 1.2 in last as my ont is 1.1 and
2: disable dhcp in my nokia router and its done!!
wifi's coming from nokia router(actually a ont) and then disabled wifi(optional) in my sharpvision ont to stop the interference with nokia wifi
