Need help in configuring Beetel 777vr1 to bridge mode.
  • Thread starter Thread starter aqswde
  • Replies Replies 5
  • Views Views 17,826
Hi All,
I want my Linksys router to do the PPPOE and NAT and just set the Beetel 777vr1 as a bridge. The interface is very confusing and I am having issues with the same.
Any help would be greatly appreciated.
If you can post a screenshot of what options you see in the WAN section of the modem's setup, should be able to guide you further.
Here is a shot in the dark, don't use VDSL but going by what I can see, you would need to change your default route the "DRoute" to your bridge interface which should be WAN4, since airtel uses VLAN tagging make sure it is tagged to whatever the pppoe2 is tagged to. You would also need to disable the modem's DHCP server for the LAN, unless it does that on its own in bridged mode.
