i have the same feeling. What's wrong, when everything logs and gets connected without a problem, then why am unable to get the internet.
I thought of using the bridge connection without the wan profile in the router. I put lan 4 on bridge and dial up PPPOe using laptop, even that does not work. i get 619 error.
as soon as plug the cable back to Nokia router boom!!! i get internet again.
may be i will call up the local tech guy to understand how does the authentication work, he has given his personal number to me, as i raised almost 10 tickets ( ) in the last one month to get bridge mode in my old ZTE router which never worked finally.
wait, you need to turn of Nokiaont, then plug out the fiber connector and then putting it into Huawei. Try this one. Also in service provision status, is ACS authentication approved?
If you have a diagnostic section in the ONT.
Try that. Ping 1.1.1.1 or 8.8.8.8
If this works, you might have a DNS issue. try putting 1.1.1.1 in lan config of the ONT.
yes yes, i turn of the router before unplugging the optic cable. "Also in service provision status, is ACS authentication approved?" i will check that in the midnight,
