Need help with zyxel pmg5617-r20b GPON Settings
Hello @R37R0_Bunny I'm not sure if your Router contains correct Firmware Version.
This issue looks like Problem with CSS on the router's website (192.168.1.1 or 192.168.0.1)
Try to upgrade your Firmware and see if it fix it or Try to Factory Reset your Modem and try it.
This issue can only be fixed by this method only. You can contact your Router Manufacture too by visiting there website and contact there customer support for more appropriate answer.
Your Router is ZyXEL (from picture)
Customer Support Website : General inquiry
