  • Replies Replies 230
  • Views Views 26,078
Tejas01
Dream big in life.
Mumbai
Airtel XStream Fiber
7. Budget 15,000-18,000.
I will try to answer point wise
2) 6.5kg (ideal) or 7 should be just enough. You will always find something to wash in it. What I don't do is wash my shoes in it. Believe it or not some people actually do that in the same washing machine.
3) LG ( thought last one was a big disappointment) or Samsung is good in Mumbai. I would have opted for one of these but when we went in for a new one in the beginning of this year we got a shock that in top loading they dont make machines with option for hot & cold water. Our entire plumbing in our house is ithe provision foe hot & cold inlets for the machine. So we bought an IFB which had this provision.
4) & 5) Parts should not be a problem for LG & Samsung in Mumbai.
6) This should not be a problem either, there should not be any problem in water pressure. I have only one floor above me & then terrace with the water tanks, I never had any problems.
7) Should fit you budget.
8) Answered above.
Any stand will increase vibration & hence noise. Where would you want to move it again in your house. I didn't understand this point.🤔. Just ensure that the machine is on level ground. Many machines have a built level meter or you can use a spirit level to check the same. Usually the demo guy checks this for you & does the needful. Like putting some padding if necessary just like wth refrigerators & cupboards. 😁
@socrates So which model did you go for?
My experiences..
Sony- two Sony bravia tv's from two relatives went kaput. The replacement part costed one of them ~50k. Another tv from my masi(Another Bravia costing 1 lakh at that time also went kaput. The damaged part was too expensive to replace. She brought another Bravia.. yeah she is Sony fanwoman).
Hitachi-my aircon ripped the life out of me whenever I needed it to work. As mentioned, I live in area prone to corrosion so it underwent corrosion leading to gas leakages and refill every year. And their CC number never worked. So this year when both my uncle and mine ac were being repaired, I found that his LG ac(he got it from his daughter in law who got it 2 years after me.) had blue fin coating to prevent corrosion. I was like, a relatively small company like LG can study Indian weather conditions and give suitable protection, big companies like hitachi can't do such small things. They charge insane amount just in the name of brand with pathetic service.
IFB- my masi(yeah the same one who got bravia) gifted her 2 year packed wm to my younger mama for use. It was good for features, but once you set the cycle and if you had some more clothes to put you would have to wait till cycle in complete. This was a deal breaker as my mama has this habit of throwing clothes anywhere and when he found them to put for washing, the machine was busy with cycle. Next came the PCB damage whose tantrums knew no bounds. The PCB was no longer available. My mami had it, sold that junk and got a semi-auto m/c. Life is peaceful now.
My uncle living on 3rd floor had water heater in top load machine from Whirlpool. But two weeks ago, the drum got damaged. The reason cited was that the heating element melted the plastic needed for stabilising the drums which finally gave way. So he told them to remove the heating element. The drum was of plastic though.
I also looked for LG front load which had heating element costing 24,000 on Amazon. Any idea of price difference in LG showroom?
Sorry for the long post...
@lucifer space constraints.
My kitchen is relatively small and the piping arrangements, drainage are made in kitchen. Going for front load would mean it would obstruct the space for opening the fridge(fl m/c and fridge would be opposite to each other). My dad is very volatile when it comes to adjustments or changes in status quo. Hell would break loose if he finds he has to do some adjustment opening the fridge or grocery items.
But main reason is cost... My dad would have closed this chapter if I told him that wm costs more than 20k. The fact that I mentioned 15k, so atleast he was open to suggestion.
But... there is a sign of hope. My dad prefers washing clothes in hot water, so now it depends if the absence of heating arrangement could make him think about getting a FL m/c. But cost is a factor. If I can get LG FL m/c in 20k, may be he could agree.
Few models of whirlpool top load have heater inbuilt.
Bosch one has provision for seperate hot n cold water so you can connect geyser pipe directly.
LG n samsung are best for service n repair but samsung have higher fault rate imo, mostly their display n sensors go crazy over time.
Front load saves water n power.
Bro I know budget is tight , but dont go for Top-load . You will simply waste money and do not get cleaner clothes as good as Front load in my personal experience . Front load is best I believe
This costs 24,000. How much price can I expect if I purchase from LG showroom?
This one is TL which I am thinking of getting.
Can anyone having LG or experience with LG w/m clarify one thing? Are their drums sealed permanently like in Bosch, Siemens or they have modular arrangement wherein you can replace the drum in case if there is any fault and not like replacing the entire assembly which is almost equivalent to getting a new w/m.
Also, how is their heating mechanism?
