  • Replies Replies 230
  • Views Views 26,078
Tejas01
Dream big in life.
Mumbai
Airtel XStream Fiber
7. Budget 15,000-18,000.
The image on the website is blurry, but there seems to be a temperature selector on the top right corner of the machine. So yes, the machine does support hot water.
Technically, you can. But there are some limitations. If yours is less than 8kg, then the drum size will be small hence limiting the motion. Also, if the blanket is heavy, then load balancing will be an issue after it gets wet.
I don't see any issue with a light blanket. You can wash 1-2 light ones without issues.
I've had a good experience with the following stand
