So got the C6 and tried to set it up using WDS. It worked great till night. But in the morning, I cannot access the net. It shows "No internet, Secured" under list of wifi's available. I have used the below videos for reference to set it up. This issue happened 8-10 times yesterday before working. Earlier i thought it was due to the range extender, so I removed it. I had also enabled WPS for 5Ghz on Nokia, so disabled it. After these steps, it got connected. But today morning it is showing the same error. Nor can I access 192.168.1.2
I have factory reset every time there was an issue because I could not access the host or my default gateway for C6. Also, if I do not select "Smart Connect" under basic settings while setting up, the router throws an error, "Refused to setup"
