Another confusion with the terminology/technology.... All the current monitors/TVs are LCD, the back light is either LED (newer) or CCFL (older). The panel itself is still an LCD, its just what is used to light them up that has changed. Its the CCFL ones that are cheaper than the LED ones.
yup I just found it out but with led backlighting they look much beautiful
dude go for AOC 18.5inch LCD , it will cost u Rs5500 max .best value for money i m using it since last 8 months , Go for it , do not waste money on 22inch LCD , because future is LED , they are all going to die
ok here are 3 monitors fr u but they are around 23-24inches they can also be used to play Xbox 360/PS3 games with inbuilt HDMI port so according to me if u have any consoles and all nd dnt have LCD/LED fr them u should totally spend 5K more and get any one of them as they are best fr gaming as well as movie watching...Most probly they should be under 15-16K.Acer G245H 24" inches around 10 to 12k full HD with 80000:1 dynamic contrast (best contrast ratio under 15k range and cheapest one with bigger screen also )LG E2350V Monitor 23" inches (check price I dont know about it yet but should be under 15k ) 50000:1dynamic contrast ratioLG W2286L-PF Monitor 24 Inches (check price I dont know about it yet but should be under 15k ) 20000:1dynamic contrast ratioLG come with LED back lighting Acer doesn't but that probly wont make huge difference any how.
