um...dunno if this helps.But I too got the error 678. Tweaked around with my router for sometime, and then found out that the ADSL link was not active...the light on my router was off...DOH!Then, I lifted my handset and voila, there is a message saying I havent paid my bills and thus disconnected (it's true ).And, now all of a sudden, the link is active again, my previous dial-up didnt work, so I created a connection (dial-up) again, and it's working!so dataone works even without the phone being active.
i used to get many errs once ,,but now a days i don geti was configured for a dial-up and the Ethernet properties had AUTO IP,,i jus change it to wat my friends were configured to manual and i specified 192.168.1.x x beein anytin in range and default gateway my modems ip:192.168.1.1 , sub net mask 255 255 255 0i am :S to see my preferred dns : 202.96.209.133alternate : 202.96.209.5i really don know where frm this came but it workssorry, i am still new to network terminologies
Gaurav,Were you able to solve your problem with the SPEEDTOUCH 330 modem? How did you configure the modem? I am running into the same problem at my dad's place. I am not sure if I have to buy a new modem from BSNL for my own connection or if I can use my SPEEDTOUCH 330 modem. Please share your experience on this.Thanks!
SPEEDTOUCH 330 modem di'nt work out with BSNL, at last I had to buy one from BSNL. Later when I switched ISP to Airtel the same BSNL modem worked, but SPEEDTOUCH again di'nt work
Gaurav,I was able to connect my SpeedTouch 330 USB on the BSNL Dataone ADSL connection. If someone wants the procedure to connect, I will forward the email I got from the Speedtouch Customer Service. All you need to do is uninstall the existing Speedtouch driver and install the driver that the CS people have sent me. That's all! And you are ready to browse.
