What is the WAN IP address range that you are typically assigned? Reboot your modem a few times and check each time to see a few different IP addresses. I suspect they are limiting users of this plan to slower parts of their network. I only get IPs in the range 59.94.[148,149,150].x while my neighbours on other plans, and even my connection before switching to this plan, would be assigned IPs from other ranges too like 61.x.x.x and the newer 117.x.x.x.
That happened to me last month. The site to check the usage was down for a while, and then came back at the end of the month when I was pretty close to exhausting my 60GB, this time displaying 2000GB (That's right, 2TB). I manged to get it down to around 1900GB before the end of the month. Could have used it much more but I ran out of things I needed to download
I think they are still fiddling with their accounting systems, so such things may happen if you are lucky.
