Night Speed Issue: SNR
  • Thread starter Thread starter amitwiz1
  • Replies Replies 1
  • Views Views 1,647
amitwiz1
Regular
BSNL Home 500C
I have seen nothing like this anywhere else. I have had my connection for 5 days and for two days speed at night were good 170-220kbps. But for the past two days, The DSL Link is lost at 11pm to 1pm and when the link is back up, I get readings shown below : Downstream UpstreamSNR Margin (dB): 6.1 6.0 Attenuation (dB): 57.5 58.3 Output Power (dBm): 10.5 19.1 Attainable Rate (Kbps): 2037 255 Rate (Kbps): 1440 258 K (number of bytes in DMT frame): 42 15 R (number of check bytes in RS code word): 0 0 S (RS code word size in DMT frame): 1 1 D (interleaver depth): 1 1 Delay (msec): 0 0Why do the SNR values go down ridiculously ?At normal times, SNR downstream is 29.0dB and attenuation is 19dBPlease help. This happens only before the 2am-8am free slot. For two days I could download 5-6gb a day, but since yesterday only 1.5gb. Speeds around 30-40kbps with frequent disconnections.
Attenuation is very high. SNR is low.Either there is some work going on BSNL side or there is an issue with the line. Observe the line yourself whether it is running next to some extreme EM interference from some motor or tubelight's magnetic ballast or something of that nature.If nothing is obvious book a complaint.
