Since the last 2 days Animal planet is exclusively in Hindi, even after changing the language settings and unplugging the set top box koi faida nahi!! :wall:
the whole channel is in hindi now
Well I can still get English Feed. I don't know more at the moment. I will see it today and than confirmed it once agian.
I faced similar problems and also sometimes the audio quality is soooo bad it almost tears my speakers off!! DishTV is slipping from Good to Bad....
Dear Amuthan,
If on contineous and daily basis you face problem with sound on this channels then try to rectify it by calling customer care, or if its some times only then it might be the case some times sound would be aproblem from channel broadcaster side as well.
