No incoming calls for 2 days
  • Thread starter Thread starter sa_kiran
  • Replies Replies 22
  • Views Views 5,004
dude....your problem still not solved.
hope it get solved 2morow.
Best of Luck with airtel. :)
I also hope for resolution. My problems started after I got 3G enabled. Calls are more important to me. 3G is anyway useless because of the unreliability. The phone shows 3G, but data transfer does not happen. And, I pay more for this non-existant or lousy service, makes me thinking of going back to EDGE.......
Airtel has not responded to my complaints yet! So typical of Airtel!I have noticed that whenever I lose 3G network, incoming calls are not received. Even with 3G network, incoming calls are not received always, calls go through after trying 2-3 times. Sometimes, I make a call from my landline, the call does not go through, I call landline from mobile and call mobile from landline, it works!
I have been getting messages from Airtel about my 3G data usage, which has been over 30% the actual usage. I called CC and asked about it. I was told to check in the phone, I told that I checked in the phone and that is the reason I called. The lady told me that they can not access the usage since the bill is not generated!I have been so sick of Airtel, particularly over the last 3 weeks, I asked that lady to deactivate my 3G connection and reactivate GPRS. I'M RECEIVING INCOMING CALLS AFTER THAT!!!! Let the idiots at Airtel figure out the problem with 3G and incoming calls, then I will reconsider 3G. I hope this is the end of incoming calls problem saga.
