not able to do office work with bsnl fibre
  • Thread starter Thread starter invisible007
  • Replies Replies 10
  • Views Views 2,358
invisible007
Jio 4G | BSNL 3G | BSNL Fiber
DEL18
Guys iam facing a weird issue .
Whenever i do office work with bsnl fibre net my office sites dont open and sometimes keeps loading , sometimes take lot of time / at night time works well .I use Cisco anyConnect VPN . Although my net works purely fine and gives 100mbps speed and pings to google etc. works fine .
Green colored ping is okay and red/ orange pings are bad . GMT is there bcoz site is located in US ..
When i use my mobile data then iam able to do office work fine .
so iam unable to decide what may be the issue . Can it be routing issue . ?
As i already told that ping and jitter as well as power is ~16.78 dBm -- looks good but only problem comes when i do office work.
So whom can i report this because if i contact my local vendor he will do speedtest check power and will say all is ok ...
m confused .. guys ,, i need ur help :(
Somewhere else on this forum I saw suggestion to set MTU in your modem/router to 1460 and then set MTU value in your VPN software to smaller than that, like 1400 maybe, tried that?
@invisible007 sometimes the VPN software does not have the option in UI but there is some config file you can edit - if you search online for it?
Or in other case, set MTU in router/modem to 1460 and in windows OS set MTU to 1400 and try? (reboot)
Nope i cant install/use any other VPN apart from the one which is installed
But i doubt it has nothing to do with vpn because when i use mobile data everything works fine
You can try changing the upstream DNS server and see if it works.
This looks like a routing issue. If your corporate n/w has more than one VPN gateway, try switching to alternate.
Usually on corporate n/w , your http/s n/w connections would go via a proxy, check your proxy settings.
