I(not me) have a Starlite SAM300 AX Modem. I use 1Mbps unlimited connection.The problem I have been facing is that. My net disconnects ever 5 minutes.I am a TriB user for 4years now and I know how to diagnose every minor problem but this time it's a MAJOR one.So here is my problem.-------------------------------------------------------TELEPHONEand Layout of my line MAIN ----> SPLITTER Quick bridge not allow multi-channel1/1/2000 0:2:40> bridge only stop1/1/2000 0:2:40> SNMP TRAP 3: link up1/1/2000 0:2:43> ppp_ready: ch:804fa7e0, iface:80445bd41/1/2000 0:2:44> SNMP TRAP 3: link up1/1/2000 0:2:44> Accept() fail1/1/2000 0:2:44> Accept() fail1/1/2000 0:2:44> Connect() to NTP server fail1/1/2000 0:2:44> adjTimeTask fail: id = 11, ip = 8c7004bd1/1/2000 0:2:44> adjTimeTask fail: no server available1/1/2000 0:2:44> adjtime task pause 60 seconds1/1/2000 0:2:44> sending request to NTP server(2d)1/1/2000 0:3:4> Connect() to NTP server fail1/1/2000 0:3:4> adjTimeTask fail: id = 11, ip = 8c7004bd1/1/2000 0:3:4> adjTimeTask fail: no server available1/1/2000 0:3:4> adjtime task pause 1 day --------------------------------------------------------------------------------------------------xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx--------------------------------------------------------------------------------------------------Now when the net is NOT WORKING ---- LOG and STATUS PAGE----------------------------------------------------------------------------------------------------Firmware Version : 2.11.38.0(UE0.C2)3.9.9.5 MAC Address : LOL LAN ------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------IP Address : 192.168.1.1 Subnet Mask : 255.255.255.0 DHCP Server : Enabled WAN ------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Virtual Circuit : PVC0PVC1PVC2PVC3PVC4PVC5PVC6PVC7 Status : Not Connected Connection Type : PPPoE IP Address : 0.0.0.0 Subnet Mask : 0.0.0.0 Default Gateway : 0.0.0.0 DNS Server : 0.0.0.0 NAT : Enabled ADSL ------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------ADSL Firmware Version : FwVer:3.9.9.5_TC3085 HwVer:T14.F7_3.0 Line State : Showtime Modulation : G.DMT Annex Mode : ANNEX_A ------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------ Downstream Upstream SNR Margin : 37.0 8.0 db Line Attenuation : 21.0 12.0 db Data Rate : 1152 896 kbps (the Satble SNR and line Att shows that there is very Low noise.)---------------------------------------------------------------------------------------------------------------------NOW THIS IS THE LINE LOG when the net is not working---------------------------------------------------------------------------------------------------------------------1/1/2000 0:2:39> SNMP TRAP 3: link up1/1/2000 0:2:39> ppp_ready: ch:804fa7e0, iface:80444b841/1/2000 0:2:39> SNMP TRAP 3: link up1/1/2000 0:2:39> Accept() fail1/1/2000 0:2:39> Accept() fail1/1/2000 0:2:44> Connect() to NTP server fail1/1/2000 0:2:44> adjTimeTask fail: id = 11, ip = 8c7004bd1/1/2000 0:2:44> adjTimeTask fail: no server available1/1/2000 0:2:44> adjtime task pause 60 seconds1/1/2000 0:2:44> sending request to NTP server(2d)1/1/2000 0:3:4> Connect() to NTP server fail1/1/2000 0:3:4> adjTimeTask fail: id = 11, ip = 8c7004bd1/1/2000 0:3:4> adjTimeTask fail: no server available1/1/2000 0:3:4> adjtime task pause 1 day1/1/2000 0:3:32> dynDNSOrgState: retry fail! shut down servicethere is sonething like CALL FAILED.. but somehow it's nt cominbg when i posted this.-----------------------------------------------------------------------------------------------------------------I'm not been able to fighure out what the problem is. Called the MTNL guys a milltion times. all they do is they make me change the DNS and stuff and it dioesn't help.Please guys guide me what to do. I'll supply with all the info you need. thanks
