OneDrive upload speed limited to 5mbps on Airtel
  • Thread starter Thread starter igloo
  • Replies Replies 65
  • Views Views 7,166
Bro I think you mean 2-5 MBps? I thought your speed is in megabits not bytes. What I have is in megabytes and on VPN. Also, don't expect the same speeds as a speedtest to remote sites that you access. Will never work. Speedtest is to the nearest local speedtest node. While I am really not sure where the Onedrive server is.
@Chip no bro I was talking about Mbps. It's too low. But it seems the Data servers are located outside India.
@Dravin Microsoft has data centres in India for their Azure cloud platform...Hyderabad, Pune and Chennai. But where the OneDrive stuff goes is not known to me.
I get full 300 Mbps upload for Google drive. But when uploading from mobile phone speeds are capped at around 580 KB/s. Anyone's having the same issue with mobile app? Seems like Google has capped mobile upload speeds. Can someone test this?
Onedrive seems to be uploading in short bursts of 525Mbps and capped to 130Mbps when downloading. All my CDN servers also get frequently replaced to Haryana or Delhi IPs.
