OpenVPN works with Airtel 4G IPv4 and not with IPv6
  • Thread starter Thread starter cwaluv
  • Replies Replies 26
  • Views Views 5,658
Mumbai
Airtel XStream Fiber 1Gbps
I am using Airtel sim. I am able to use my Home OpenVPN and OpenVPN (via Linode). OpenVPN only works when Airtel 4G has IPv4. Whenever Airtel 4G changes to IPv6, all my OpenVPN's stop working. Later, just to test, I disabled and enabled Airtel sim on my phone and then I got IPv4 and my OpenVPN's started working again. What is happening here? Anybody?
All cellular providers..not sure about BSNL/MTNL duo...use a dual stack nowadays..a CGNAT v4 + public IPv6 address. Why are you using it over mobile instead of fibre? With fibre you can get a static v4 public IP.
I have OpenVPN setup with a Static IP using pfSense firewall in my house. When I travel, I connect to my home network using OpenVPN with Airtel 4G on my phone. Whenever Airtel 4G is using IPv4, I am able to connect to my home network and when Airtel 4G uses IPv6, I am not able to connect to my home network.
Later, just to test, I disabled and enabled Airtel sim on my phone and then I got IPv4 and my home OpenVPN's started working again. What is happening here? Anybody?
Your phone will 1st get a v4 and then it'll use the v4 to get a v6 via RA/DHCP6. That's how its done even on fibre connections.
So if you expect only v4 connectivity you're out of luck.
What I am saying is that this behavior ie dual stack is default behaviour on all carriers. There's no way to get around it.
When a remote server doesnt respond to v6 it should automatically switch to v4 at least in theory. I can ping my mobile phone's IPv6 address but not the mobile's v4 as it is a CGNAT, from my desktop machine. And I am sure it would work the other way around too...if an iPhone allowed me to use ping. Have you set up incoming firewall rules? Also start using a dynDNS or similar service to map your IPs to your domain.
You may also want to see this - How to use OpenVPN to access your home network through the Wi-Fi Routers
Sorry, I'm not using TP-Link router. My OpenVPN is setup using pfsense firewall on my custom PC with Intel Quad Port NIC. Everything is setup perfectly. Anyways, I have a question for you. When will IPv6 become standardized in India?
Sir, you didn't understand my question. I already have a Static IPv4 from Airtel XStream fiber which I have used to configure my OpenVPN in pfsense firewall. Why would I need dyndns when I'm already paying for a static IP address ₹199/month?
Maybe, I didn't phrase my question properly. That's why you couldn't understand.
Your phone is trying to find a v4 address using v6 that's why you cannot connect. You don't need a TP-Link router to follow the instructions there just follow the principles outlined. I use pfSense too but without OVPN as a gateway...Check the pfSense support forums at Netgate.com for detailed help. They have a wealth of info there including setting up firewall rules - OpenVPN Remote Access Configuration Example
In short - ipv6 can connect to only ipv6 addresses and ipv4 to ipv4 only.
You have static ipv4 on fiber and you have to connect that with ipv4 only.
To connect with ipv6 from mobile , configure ipv6 in your fiber router and openVpn.
