Passive Power Injector for Power-over-Ethernet
  • Thread starter Thread starter tellanand
  • Replies Replies 8
  • Views Views 812
Chennai
Hathway, Airtel
Does anyone have experience using a passive PoE power injector? I am contemplating on buying a passive PoE power injector from Amazon.in (see below):
The question I have is, does this support Gigabit speed or does it support only 10/100 Mbps speeds? Its not clear from the specifications.
Thanks in advance for any insights?
I have one of these, its only 10/100, ethernet only has four wires
Rest four are used for power.
Lower voltages (12V) will degrade much quicker compared to higher voltage PoE 24v/48v due to resistance.
Make sure the cable quality is good and not too long before buying this.
Thanks @JB700 . That was very helpful.
I think I'll go for an active injector.
I need to supply 5V. Do you have a view on this:
Ah yeah, I forgot to mention that. TP-Link also has a splitter Robot Check
which allows to split power back from PoE. Without splitter it won't work without 802.3af support
