Peculiar problem with D-Link DSL-2750U
  • Thread starter Thread starter Sai
  • Replies Replies 7
  • Views Views 1,801
Sai
Galaxy Far Far Away
Tata
So my uncle bought this modem from D-Link recently and the thing just wouldn't connect to BSNL Broadband in his place. All other modems work fine in his place. I took same problematic modem to my place to check and it works perfectly fine here.
What could be the issue ?. He uses a desktop powered by Windows 7.
I am using the exact same model on BSNL and it works fine... Maybe call bsnl support, they may be able to help you through any changes in setup..
I use BSNL Broadband and the same modem works fine in my place. It's just that this modem does not work in uncle's place. He has a backup modem and that works fine in his place.
Only thing I can think of is user name and password combination.
unless you are using usb to connect to the router, there is no relation between the computer and the modem/router. if the router is working, it would work on your phone. and if it does work on your phone, there is something wrong on the computer.
