Hi All,
This is Sandeep, I stay at Lothkunta, Secunderabad. Currently I am using Reliance Netconnect datacard, earlier I was using BSNL Broadband, becoz of underground cable problem in our area it use to disconnect frequently. But still I like BSNL speed and its wireless service.
List of requirements:
1. Need wifi for my devices.
2. Frequent disconnect should not be the problem.
3. Speedtest report in my area.
4. Wifi should work for my entire house (4 Rooms)
5. Which Router should I go for(provided by Beam Vs Other).
6. Must not have wire cutting problem (This is the reason for datacard).
Let me know anybody from my area. If everything goes will then vil plan for B-Max 1020. Can directly mail to : [email protected]
Thanks in Advance.
Sandeep
Thanks in Advance.
Sandeep
