How did you get 12 coupon at initial setup?i am using 329 plan with 6GB data unlimited calls valid for 84days. auto topup via my jio app gives Rs.50 discount via 12 coupon given at initial setup.
comes to 93 per 28days.
I am also using same plan in Delhi.... internet is good.... better than Airtel or Vodafone.... getting 4G+ at most places....@igloo How reliable is the internet connectivity?
See if you make a lot of calls, get the ₹129 Jio plan, since it gives unlimited calls plus 2Gb data.
If data is more of a priority, I’d suggest going for Airtel‘s ₹79 plan + ₹49 plan. The ₹79 plan gives you ₹63 talktime for making calls and the ₹49 adds 3Gb of data which is 2Gb more than the ₹129 plan of Airtel plus 4 extra days of validity.
Jio‘s is value for money overall ofcourse if you intend to make lots of voice calls. Otherwise if you take the Airtel combo ₹79 + ₹49 = ₹128, you get overall value on data use.
I did not get that part...
Coverage is the best. LTE only mode on samsung phones made battery drain to minimal. Speed has increased to double digit most of the time after recent spectrum addition. 10mhz@ band 3 and band 5.@igloo How reliable is the internet connectivity?
Yeah I have a secondary SIM on just this plan. It's an excellent long term plan. Gives validity for an entire year at such a low cost. No private operator has such a cheap plan with such a long validity.I am using this plan from BSNL as I do not need data on the 2nd sim. Mainly use it for incoming(OTP etc...)
