Port Forwarding not working with Airtel Dragonpath (707GR1)
  • Thread starter Thread starter Zenithx99
  • Replies Replies 12
  • Views Views 13,983
Try assigning a static ip for your ps4 and then configure port forwarding, you'd not need to forward 80, 443 for games. Also if your UPNP is enable, it should automatically be forwarded.
If none of the above solutions work, remove all port forwarding rules, and put your device ip in DMZ and see if it works.
Remember, you'd not get Type 1 NAT no matter what.
Hi
I also need help on port farwarding on this airtel 707GR1. although tried no-ip which some time works and other times not.
even if it works i can only able to reach to router configuration page..
Also Remote Access page FTP,HTTP everything is showing disabled.
Although could able to use my Home Assistant using Cloudflare but still want to use it using no-ip etc.
Thanks if any one can help with this.
