Possible solution to MTNL NU Problem
  • Thread starter Thread starter cyberwiz
  • Replies Replies 63
  • Views Views 27,810
Status
Not open for further replies.
My firmware ver. No is V2.00B01T01.ML.20050530from where i can download new one.orwhere's D-Link office in mumbai
it's the latest one...u don't need to upgrade it... :)
still if u want the address, here u go...
D-Link (India) Limited
Plot No.5, Kurla-Bandra Complex Road
Off C.S.T Road, Santacruz (E)
Bombay - 400 098
Tel: 91-22-6526578/ 6526623/ 6526696/ 6526788
Fax: 91-22-6528476/ 6528914
General: skadam@D-Link-india.com
yehh!!!Means Mumbai mtnl people gave me the modem with new firmware ver when i replaced it a month back!!!!!!
well, i think all the new modems after May 30 are coming with the new firmware...even i got the modem with latest firmware today itself, in Delhi :)
Originally posted by cyberwiz@Jul 27 2005, 05:49 PM
Hi Guys,
Refer to the 1st post in this topic. I have finally tried the solution on my DSL 502T and it WORKS !!
The only additional thing which u need to do in addition to the things already mentioned in the 1st post is to disable DHCP from Home>>DHCP in the modem settings page and assign a static IP to ur lan card...use 192.168.1.3 ; put the mask in as 255.255.255.0  and Gateway as 192.168.1.1 ; use the foll DNS - Primary 203.94.243.70 ; secondary 203.94.227.70
Save and reboot >> Goto Network connections in Ctrl panel >> Create a new connection >> connect to the internet >> setup my connection manually >> connect using broadband connection that requires username & password >> Put in the ISP name ie MTNL >> put  in ur username and password >> add a shrtcut (will make it easy to find after setting up the connex.)
Thats it...But be careful i have tried this on my router only after i have got the firmware upgraded...coz i crashed even my newly replaced router  :P
FYI, the bug-free firmware ver. No is V2.00B01T01.ML.20050530
The last 8 digits are the key and indicate the date of the firmware...read it backwards ie 30/05/2005 ...any prior date firmware is bound to have problems so dont try it before u upgrade  :)
[snapback]18476[/snapback]
[/quote]
Thanx cyberwiz I've successfully set up my DSL 502-T router in bridge mode.
And by far working flawless.
Originally posted by cyberwiz@Jul 13 2005, 08:12 PM
Now to automate the process download and install any task scheduler which has the capability of dialing network connections. U can also use the default windows task scheduler but that didnt work for me and i use advanced task scheduler to do the job for me. It flawlessly dials at 12:05 AM and disconnects at 7:50 AM
I was using Advanced Task Scheduler for quite sometime now and it was working great until a few days back my norton antivirus started detecting the advschedule.exe file as a trojan!!! Yes, norton detected advanced task scheduler as a virus. The trojan was called Backdoor.Darkmoon
Every 10 mins norton wud popup a virus alert saying that the .exe was a trojan and it cudnt repair it nor delete it coz it didnt have access to the file. So i finally uninstalled it which too didnt complete successfully coz the advschedule.exe file cud not be removed. Anywayz, finally norton itself removed that file which was the only file remaining in the installation folder. Advanced task scheduler was also slowing down my windows startup and norton wud take longer than usual to start the autoprotect. I didnt mind the system and norton loading slowly but after it was detected as a virus, i had to uninstalled advanced task scheduler. After i uninstalled it the booting started normally and norton loaded much faster.
So im writing this post to warn all u guys who r using advanced task scheduler, to plz uninstall it and search for another task scheduler. I myself am now searching for another one. Windows Task Scheduler sucks. It cant run the mtnl dialer i created after using bridge mode for the router. So does anyone know another task scheduler that works equally good as advanced task scheduler but does not mess with the windows startup or norton and ofcourse is not prone to viruses??? Plz let me know. Thanx.
i suggest u simply use rasdial if u are on windows xp its simplejust make a .bat file with the following command "rasdial nameofconnection login passwd" and set it for 1205 make another batch file with the command "rasdial /disconnect nameofconnection" just check the syntaxes... for the correct syntax make a daily task and set it to repeat every 1 minif u want to reboot your pc along with it make a 3rd batch file and set it for ... shutdown -f have fun experimenting
after going thru all those screwing up of routers.. Just for my knowledge I want to know if using the 'small reset button' (small one on the back side) on the router doesn't restore the factory settings ?????
Status
