Problem after migrating to Unlimited Plan -749
  • Thread starter Thread starter rohit0103
  • Replies Replies 3
  • Views Views 1,645
rohit0103
airtel
Hi All,I have some queries regarding Braodband and Airtel Broadband specifically, which I am sure you will be able to help out with your expertise.First, a brief background.I am based in Pune.Am into IT but not much technical hand-on, so I dont experiment much with settings etc.I was on a Limited Broadband till 15 Jan, after which I migrated to Rs 749 Unlimited broadband-m 256kbps.I was and am still currently on PPPoE, meaning I have to dialup from my computer to access Broadband using a userid/passwd. Have aBeetel modem provided by Airtel.After migration, I have noticed a few things and I need your advise.1. The broadband connection keeps dropping off. Sometimes, it will get disconnected on its own although the dialup shows it is connected. I have to manually disconnect and re-dial. it becomes a problem if I keep my laptop on during night for torrents.It is on through out night and in the morning, hardly anything has been downloaded.2. The torrent speed has surprisingly dropped. Initially, when Usage based plan, I could get torrent speeds upto 70-80 in night. Now, hardly 30-40. is it right/ok based on your experience?Now, the queries :1. What can be done to resolve issue #1 ? Should I change my setting to "Always on" broadband ?I believe the technical term is a Bridge connection ? is that correct ?? Will that resolve the problem or should there be something else ? Will "Always on" Braodband impact my speed ??2. Issue #2 : Any tips to increase the download speed of the toreents?3. I read through some topisc where the suggestion was to use PPPoE for Unlimited and Bridge for Limited Broadband. Why is it so? Again, which should be used ?4. Basically, what I want is that I should not get disconnected when I leave my connection on during night or normal surfing, which did not use to happend before. What should be done to resolve this ? Change of connection type or somne settings ?? I have not still complained to Airtel as I want to undertand the problem first, before I complain and then backtrack because of the crap thrown at me by their technical team.I hope I have clarified and you will be able to help me,ThanksRohit
first u should migrate to 649 plan in which you get all existing plan + 100 Rs call also the other you should keep complaining till they do not shift there dp or your signal keep drop
i guess the same plans are available at different rates in different part of the country.i believe you are referring to Starter 649 (Airtel/UE/FL/011) in UP(E) area.the same is for Maharashtra and Goa as Browser 749 - One Airtel (Airtel/MH/FL/4).
I have noticed for past 2 days..this is basically happening with torrents..at night, I switch on torrents..till I am surfing etc..its ok..and when I go to sleep..probably after 1-2 hr..the connection simply drops off..has anyone else experienced the same problem ? with torrents..and how to resolve this ??
