Problem Connecting the PCs..
GadgetGuru12
Regular
BSNL Home 1800
Hi..I have,8mbps 2799 Plan active.Terracom Type 2 Modem [wifi switched off.]D-Link DIR-615 Connected to the modem for wifi and 3 PCs ethernet port connecting. ---------------------------------------Now problem is, when I switch on the iMac or a PC for the first time, it always says,"Some other PC is using 192.168.1.52 already, contact your network admin".That means, I guess, the router is trying to assign the IPs to the systems, but how can it assign the same one ?I never heard anything like this. I know, the router once given a range for DHCP, will assign unique to each device.My devices are not on RESERVED IP list on the router at all.I have just keep the DHCP server on and IP range as 192.168.1.50 to 192.168.1.70 :huh:Now, I dont know, whats the problem.Then after f**king with some options, I get through the error msg and internet comes to the iMac.But now, when I switch on the PCs, they dont even identify the internet, al though they are drectly connected to the router ports.Damn, I dont know, whats going wrong. .. :madness::madness:
