Problem In Bridge Mode
  • Thread starter Thread starter arnav_ch
  • Replies Replies 5
  • Views Views 1,819
arnav_ch
Regulars
2 mbps @ 849NU(MTNL)
i am facing a peculiar problem.when i connect in bridge mode, the connects starts but the status is shows as registering your computer on the network.i can use the net nut, i have batch file to connect at 12 which is not working.if u manully connect it works for the full 8 hrs while status is registering while if i connect using the bat file, the connects lasts aroung 5 mins.either i need a solution so that connect is perfectly started or, a scheduler which can start the connection at 12 and stop at 8 without disconnecting after 5 mins.
well, even i had that prob in the beta version...and in the RTM version, it's the same but the net never worked, unlike the beta version...i cudn't find any solution to any of them :(
but i am runnoing the retaial version.how r u connecting now??will any sceduler work??
my vista crashed thrice...so am back on xp...though have transformed my xp to vista...so that's cool...
here is my desktop :D
http://img66.imageshack.us/my.php?image=mydesktop1tq6.jpg
