DS Line Attenuation 29 US Line Attenuation 15
seems acceptable. . DS means downstream and US =upstream.
SNR is the Signal to
noise available in your setup/modem. The higher the better. minimum 10 db recommended. I will search my computer for screen shots if available) of your modem and will post later.
Since your computer is new, only thing to do now to increase speed is to try some program.
Try connection Booster from
www.trackzapper.com
Just select Default values , recommended by the program. Since sites are working
use computer for a week or so , and then try this to increase speed.Not really needed.
Always try things, you are confident about. Report any difficulty.
I am anxious, that your Internet connection and computer should work without any
problem.
By the way [ quote ] hello there [/ quote ] ( without space ) extract from a post
will appear hello there
. try this. Do not use the Quote option here and repeat the full message.
